ics Win 98 and Xp
ics Win 98 and Xp
Has anyone succesfully setup ics from a Win98 host to an XP client. If so - any tips please - it's got me beat Sad
ics Win 98 and Xp
This link I've found usefull in the past.
It gives a tutorial on setting up ICS on any any OS, you run through
the options choosing which system to set up as host and then
which system to set up as client. Thers also a good troubleshooting
section. Maybe it's of help.
ics Win 98 and Xp
Thanks for that link Aleca, I'll have a read through it. Using the ics wizard completely screwed the Win98 machine which is the one with the connection. I've suggested to the 'client' that they should get a router so I'm hoping they'll take the advice but if not then I'll plough through the process in the link and see if I can get it working.....
