i have a vireus help
i have avg anit virus it has found "trojan horse download small 4.d" it cleans it but then when i check its gone its back can anyone help me get ride of it i havent found any solution yet
many thanks
Have you actually deleted it from the virus vault or where ever avg keeps suspect files.
Andy.
hi it wont delet it says it cleans it
even went to where its stored temp internet and delet it but it comes back
many thanks
What O/S are you using? What is the virus? Is it a virus or a trojan horse ? A trojan is normaly there to take control of your pc a virus trys to destroy your data or infect others.
If its WinME your using then often it keep the virus in the system restore which can cause the problem.
hi thanks the machine is runing on win2000 and
it says its a "trojan horse download small 4.d" that the pc has. i am not a 100% sure but think we have solved it i looked in add and remove progs and there wasa program with same name as what the file that has "trojan horse download small 4.d" so i uninstalled it
i will let you know if we sort it
many thank
i have done a few virus scans and it has gone my uninstalling must have taken affending trojen out
many thank
