.htaccess not working
I have created a folder on my own server (one at home, not the plus net ones) and i have a .htaccess and a .htpasswd file in there.. i have the htaccess set up correctly yet it isnt working
Is there anything i have to do to apache to get it to work?
I would conclude you may not have it setup correctly as apache does not normally need any config changes to recognise it.
Can you post what you have in .htaccess and the full path to your web directory, and where you have put the htpasswd file?
Web DIR: /var/www/html/
htaccess: /var/www/html/files/.htaccess
htpasswd: /var/www/html/files/.htpasswd
contents of htaccess:
AuthUserFile /var/www/html/files/.htpasswd
AuthGroupFile /dev/null
AuthName "Please Login"
AuthType Basic
require valid-user
ErrorDocument 401 "401"
ErrorDocument 404 "404"
can someone help me please..
Can't see anything obviously wrong unless you spelt either .htaccess or .htpasswd incorrectly in the locations you stated.
Are the files world readable - i.e. chmod 705 (or 707). try chmod 777 and see if that helps.
Are there any errors reported in the apache logs?
Have you changed the apache http.conf file? Check the section related to .htaccess has not been commented out.
It appears that it was disabled in the httpd.conf file.. it was set to AllowOverwrite None
which i changed to All and now it works
Thanks for the help Cheesy
Glad it was something simple.
