how can i creat Index of / on my server
hi all i have a server hosting direct admin iam trying to put some files on there
i need the server to say Index of / then display all of my files and maybe add a password dos any on know how this is done
so it show Index of / the directorys thank all
Showing an index listing is the default behaviour for a directory as long as no index.html, index.htm, index.php file exists and you have not disabled directory listings in a .htaccess file.
To password protect directories, use .htaccess. The General: .htaccess tutorial expalins how to do this.
Thanks for your promt reply so as long as i dont make an index it should work iam not useing plus.net servers thanks again
That is the default setting for PlusNet webserver. Other hosting services may be different.
