help tweaking mIRC
help tweaking mIRC
lo there. hope someone can help me here. i have "flashing" set in options so i know when there are new channel messages but i idle on a bunch of channels and some of these i'd rather not be bugged about channel messages. currently i have to right click on each channel's tab to deselect "flashing" everytime i connect. is it possible to define that i don't want a specific channel to have "flashing" enabled? (perhaps in my perform). an example perform follows (can i ammend it t stop flashing?)
/join #eWc-clan
thx
help tweaking mIRC
A lot depends what script you are using for mirc. I would take a look at
http://www.mircscripts.com/scripts/6.0.html many of these free scripts give you lots of extras not in the basic mirc. Many of the scripts are aimed at a certain market say XDCC and have all sorts of functions.
Its a matter of trying the diffrent ones to see which best suits your requirments
help tweaking mIRC
hmm, that site looks familar lol - must have been there a while ago.
thanks for the reply but didn't find anything of much use to me.
thx anyway
think i'll just give up Sad
