guestbook
guestbook
I have been looking around the site but cannot see any help in hosting my guestbook via plus net. Can anyone let me know if its possible and where I can read the help files etc.
regards
mark
guestbook
I dont know of any help files on the portal but yes you can host a guest book here.
I in fact have one for my domain www.hmrg.co.uk.
The important thing is that is has to be hosted on the CGI server and not on the main server "htdocs"
Some accounts dont have CGI server access (e.g. Pay as you go)so it does depend on just what type of account you have.
There is a tutorial though on the CGI server at this location
thanks
Thanks I have been reading most of the weekend just keep getting internal 500 error no matter what i do so driving me crazy at mo.
guestbook
Please post a URL to your guestbook.
Is this on your www or cgi webspace? if cgi. remember html and php files cannpt be put in the cgi-bin directory.
A 500 error normally means you have bad HTML/perl/php code and it is not generating the page correctly . Just make sure you have installed all the files correctly as the instructions tell you and make sure all file permissions are correct.
guest book not working
I don't know how as I have not even added any code just trying to get it to run first first b4 I config it. I have posted the top part my guestbook.pl which sits in my cgi-bin with file attributes 755
my addguest html page has only had my cgi address added and I have made no changed to the guestbook log or guestbook page.
Any help would be great as been working on it now for 3 days, all the file attributes are 766 with those files.
http://www.baggies.co.uk/guestbook.html
top of my guestbook.pl file
#!/usr/bin/perl
# Guestbook Version 2.3.1 #
# Copyright 1996 Matt Wright mattw@scriptarchive.com #
# Created 4/21/95 Last Modified 10/29/95 #
# Scripts Archive at: http://www.scriptarchive.com/ #
# COPYRIGHT NOTICE #
# Copyright 1996 Matthew M. Wright All Rights Reserved. #
# Guestbook may be used and modified free of charge by anyone so long as #
# this copyright notice and the comments above remain intact. By using this #
# code you agree to indemnify Matthew M. Wright from any liability that #
# might arise from it's use. #
# Selling the code for this program without prior written consent is #
# expressly forbidden. In other words, please ask first before you try and #
# make money off of my program. #
# Obtain permission before redistributing this software over the Internet or #
# in any other medium. In all cases copyright and header must remain intact.#
# Set Variables
$guestbookurl = "http://www.baggies666.co.uk/guestbook.html";
$guestbookreal = "/files/home1/baggies666/guestbook.html";
$guestlog = "/files/home1/baggies666/guestlog.html";
$cgiurl = "http://cgi.baggies666.plus.com/cgi-bin/guestbook.pl";
$date_command = "/files/home1/baggies666/usr/bin/date";
# Set Your Options:
$mail = 1; # 1 = Yes; 0 = No
$uselog = 1; # 1 = Yes; 0 = No
$linkmail = 1; # 1 = Yes; 0 = No
$separator = 1; # 1 = <hr>; 0 = <p>
$redirection = 1; # 1 = Yes; 0 = No
$entry_order = 1; # 1 = Newest entries added first;
# 0 = Newest Entries added last.
$remote_mail = 0; # 1 = Yes; 0 = No
$allow_html = 1; # 1 = Yes; 0 = No
$line_breaks = 0; # 1 = Yes; 0 = No
# If you answered 1 to $mail or $remote_mail you will need to fill out
# these variables below:
$mailprog = '/usr/sbin/sendmail -i -t';
$recipient = 'webmaster@baggies666.co.uk';
# Done[/code]
guestbook
1) Your URL was wrong. It should have been http://www.baggies666.co.uk/guestbook.html
2) The date command is wrong:
Should be
$date_command = "/usr/bin/date";
3) The other problem is the cgi server webspace is completely separate from your www webspace. This means you cannot access any files on the cgi server from the www server. i.e. You cannot access guestlog.html (which is on the cgi server in /files/home1/baggies666/) as http://www.baggies666.co.uk/guestlog.html
guestbook
yea sorry trying to do things fast again input the web page wrong .
I can change the date line but confused about the item 3. I am not sure what I should be changing, my guestlog should be on my mine server and only the pl file on my cgi.
guestbook
The guestlog is written by your perl script so can ONLY be saved on the cgi server.
thanks
Thanks I have at last got my head around it and got it working so juts going to play with it a little more so my understnading improves.
