grc.com shieldsup results
Just ran all service ports test in shields up, here are the results:
GRC Port Authority Report created on UTC: 2005-06-05 at 13:21:47
Results from scan of ports: 0-1055
0 Ports Open
1053 Ports Closed
3 Ports Stealth
1056 Ports Tested
NO PORTS were found to be OPEN.
Ports found to be STEALTH were: 0, 135, 445
Other than what is listed above, all ports are CLOSED.
TruStealth: FAILED - NOT all tested ports were STEALTH,
- NO unsolicited packets were received,
- NO Ping reply (ICMP Echo) was received.
Running a 3com firewall/router (3CRWE754G72-A) also ZA Security suite version 5.5.094.000.
I can't understand why my ports have changed to closed when the last time I ran the test they were all Stealth. I have ran a virus check, trojan check and checked for spyware and adware, all OK
Can you describe your setup? are you connecting via a modem or router? and what firewall software are you using?
When you tested before did you have the router acting as a firewall? Last time I tested through a router (using Sygate or Mcafee) it found all ports closed none stealthed and said that I was possibly behind a router. The router is supposed to be the better firewall, if configured correctly, but can give strange results on scans.
Try all the Sygate scans as a double check, just google for sygate.
I thought that it was bad practice to use a router firewall plus a software firewall as they can cause problems, or is that only for 2 software firewalls?
A hardware firewall (router) and software firewall is good practice. It's only two software firewalls which cause problems.
I'm currently not running a s/ware firewall as I've yet to find one I fully like and can configure how I like using 'proper' rules (My linux box is the exception - iptables Wink.
Is there anything even close to iptables for a WinXP box? (I've got two win xp laptops - one's mine but has no w/lan drivers for linux the ndiswrapper ones fail to work reliably and the other is the wife's who needs M$)
Jetico is a good firewall, espcially if you've got a good understand of the rules needed in a firewall.
It works by a series of tables, and each packet drops though these tables until if finds a suitable rule or a reject rules.
The system has a number of automatiically defined rules, but the rest are upto you, and any system generated ones, by you answer Yes to allow access are detailed ones.
Give it a shot, it's what I use.
Oh and it's free, and it's very light on resource and very quick
Ta, that's exactly what I need (IE no frills, no second guessing my intentions etc)
