ftp speeds
Denzil
ftp speeds
Hi All,
I use Suse 9.1 Linux for most purposes, but have a copy of WinXP as aboot option. When managing my webspace - uploading files, deleting files etc. - I have tried two or three different ftp clients in Linux and they are all incredibly slow. For example to replace one 5Kb file took about 5 minutes.
Out of interest I tried the same thing on WinXP with a freeware ftp client and I uploaded a few files and deleted a load of original ones in a matter of seconds.
So, presumably I am doing something wrong with the Linux ftp. Any ideas? :?
Denzil
ftp speeds
So nobody in Plusnetland knows anything about using ftp with Linux? :? I am surprised at you all!
ftp speeds
try pftp mew
ftp speeds
Do you have the firewall enabled on Linux. If so try disabling it and see if your FTP is any quicker. Or try passive and non-passive FTP modes, passive is often better behind a firewall.
Denzil
ftp speeds
I do have the firewall enabled, there is also a firewall in the router but that is the same for Windows. Hmm, I'll have a play. Thanks guys.
