echo test works but calling BT line fails using XLITE
swynford
I am using XLITE release 1103m (supports multiple proxies) and am trying to establish outbound calls using Plustalk.
Using an echo test works (eg calling *393 613) - it connects and I can hear my voice echoing,
However, calling any BT line fails. The BT line rings but I get no ringing tone on the XLITE.
I answer the BT line and it goes silent, however the XLITE disconnects and I get a 403 forbidden or other message.
Any clues?
thanks
Sad Sad
1 REPLY
Plusnet Staff
Plusnet Staff
There was a problem with the Broadband Phone service earlier:
http://usertools.plus.net/status/archive/1174485726.htm
it's now been fixed so it should work, you may need to log off and back on, but if you can try it again you should be able to make a call.
