dvxa_sig on desktop
tonka
dvxa_sig on desktop
hi folks hope you can help me its driving me mad i have a desktop icon that keep's coming up on my desktop its a dvxa_sig i keep deleting it but it keep's coming back ,it doesn't show up in the control panel and i can't find it in temporary internet files i run adaware scan and spybot it has been coming back when spybot is running dont know why.
dvxa_sig on desktop
Have you tried running msconfig and see if anything is in there?
tonka
dvxa_sig on desktop
yes mate no joy there either.
dvxa_sig on desktop
See "dxva_sig" appearing on my desktop.
Getting the filename wrong meant it took me a bit longer to find Wink
Remember, Google is your friend and can often find the answer (when spelt correctly). Do a search for dxva_sig to find some other solutions.
tonka
dvxa_sig on desktop
cheers guy's i forgot to use goggle take it for granted sometimes ,anyway it is a codex for window's media player downloaded player 10 ok now.
