domain name ?
domain name ?
hi just woundering if i was to buy a domain name would it be set up automatic
or would i have to set it up. Iam on building a site and uploading it via ftp at the moment be great if some one could advice thanks
domain name ?
If you got a domain name through plusnet it would automatically perform the same role as your www.username.plus.com and mailbox@username.plus.com webspace and email addresses.
Chris
thank you
Thanks very mutch for your reply it was most helpfulat least i noi supose getting a co.uk would get more people to a web page
regards gareth
domain name ?
Just to add to Chis's comment.
You can also put all the files for the domain in their own folder within your web space.
This has the advantage of leaving your www.username .plus.com domain totally seperate so in effect you have 2 domains.
All you would have to do to achieve this it to go to Domain names on the left of this screen and tell the system which folder to use for the domain.
After making this change it can take 24 hours for it to come into effect.
