domain name in plus.net pop3
i have got a domain name transfered in to plus.net, i can see this in the domains list,
email is set to pop3.
How do i go about adding email address for the new domain and were do i need to point out look to access pop3 mail box;s for the domian.
thank you in advance for any help!
Rich
You domain email comes to your default username.plus.com address.
You can add mail boxes, as many as you like. See this guide from the help section for more details.
If you can I'd recommend imap servers instead. This means your mail is always backed up somehwere different if your system fails and you can access all your mail and folders etc from any web connection.
i take it from your logon rdbgroup that you are a business. I map could potentially save you lots of hassle should the worst happen.
I have my mail set up this way and can access any mail I've sent from any net connected pc at the drop of a hat.
A
