does it matter if i click on pop?
I check my mail via the portal a fair bit. Does it matter if i click on POP by mistake? :?
I usually use PN's IMAP server and Thunderbird at home.
When using webmail. it does not matter what option your choose (POP or IMAP) as this is completely indepenent of any email client you are using on your PC.
The only difference is when using webmail POP, you cannot see/use any additional folders you may have setup via IMAP as POP does not support folders.
oh, good, thanks
