connecting usb dect phone to Xlite program
can anyone help with connecting USB DECT phone GT1900U to the Xlite service so that we can use the phone to Dial out via the PC. When we connect via skype the service recognizes the phone connection. we want to be able to use Xlite with the phone to use our plustalk 240 free minutes
Have you tried X-Lite Mate?
It can be downloaded from here:
http://www.waitec.com/waitec/filelistview/371?cat=driver
or X-TenMate beta from here:
http://www.yealink.com/en/otherdown.asp
(I haven't tried the beta)
Thanks for your reply.
Yeah ive installed both and they both show up on my toolbar as a red icon, and says "can't find usb phone" even though it is blatantly plugged in.
I'm beginning to come to the conclusion that there is no way that i can connect the two, that they are not compatible - even theough i was told by Plus Net that i could use ANY voip phone. So i was just wondering if you or someone could recommend me a good piece of hardware that does work with Xlite. I prefereble would like a phone handset but a mike and earpiece would also do, but i really would like one which is wireless, and prefereably not costing more than £50 or £60.
Any suggestions.
This one
This is what i have http://www.cclonline.com/product-info.asp?product_id=3486&category_id=239 . I have bought several other things from this firm and can recomend them.
