confused
cookie141
confused
Hi.
Help please..........
I have retrieved my old freeserve mail account (Wanadoo) for the sake of sending photo attachments...the prob is i can receive mail but cannot send.
I have set my incoming mail(POP3) pop.wanadoo.co.uk
outgoing mail(SMPT) smpt.relay.plus.net
But i keep on getting this error message (As Below)
The host 'smtp.relay.plus.net' could not be found. Please verify that you have entered the server name correctly. Account: 'pop.wanadoo.co.uk', Server: 'smtp.relay.plus.net', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 11004, Error Number: 0x800CCC0D
Any ideas round this prob would be welcome.
Cheers Cookie
confused
It's just relay.plus.net
confused
Try using the method here http://portal.plus.net/central/forums/viewtopic.php?t=13347
If you no response from telenet, it's most likely a firewall blocking it.
cookie141
confused
sorry about posting again
here is the error message i am getting
An unknown error has occurred. Subject '', Account: 'pop.wanadoo.co.uk', Server: 'relay.plus.net', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: 0x800CCC0B
confused
The error message you are seeing is the simptoms that you have your from address set wrong.
cookie141
confused
yes i am aware .here is the errror message i keep on getting An unknown error has occurred. Subject '', Account: 'pop.wanadoo.co.uk', Server: 'relay.plus.net', Protocol: SMTP, Port: 25, Secure(SSL): No, Error Number: 0x800CCC0B
confused
This is connecting via Plus.net dialup/broadband right?
Do you have another account set up using relay.plus.net which is working?
confused
I'll try again
The error code 0x800CCC0B arrises when you are using the wrong "from" address in your software.
Are you sure this is correct?
cookie141
confused
sorted it out
cheers
