checkpoint secure client problems
anyone using secure client out there? I autheticate with my firewall no problem but connection fails. Nothing in the firewall logs. Retry anything between 2 and 10 times and eventually I connect. We upgraded and replaced the firewall on Friday and I am the only user with a problem so it is not firewall related. I also was working iwht another ADSL suipplier for 3+ years using same modem, filter, client etc with no problems.
Also when connected I disconnected with the message ip address has changed. Strangely I have monitored my ip address and it doesn't actually chnage!!
Anyone else using it out there?
CheckPoint secure client works fine for me, from my Plus.Net6 connection.
Which version are you using?
I know the one I am using is a few versions back, I have just been ask by out IT department to update.
Chilly
Do you have a static ip address?
