can' link out of cgi-bin
i've got a website on www.visitholyhead.com.
everything's running fine, until you choose to book online.
once you've picked the page, all the links seem to look for links here (http://cgi.studmeister.plus.com/form/www.studmeister.plus.com/scenery.htm) instead of www.studmeister.plus.com/scenery).
i've tried several alternatives to try and get the links to work correctly, but can't seem to manage Evil .
any suggestions?
the site was created using dreamweaver and used a template.
thanks
[Moderators note (by Thomas): Stray bold tag removed.]
Just a guess but maybe you need to use relative paths rather than absolute paths when specifying URL links. There is an option somewhere in dreamweaver to do that but can't remember where.
I may be wrong, but I think the problem is that you're linking to www.studmeister.plus.com/scenery whereas you should be linking to http://www.studmeister.plus.com/scenery - the initial http:// is important, otherwise the linked address is just appended to the end of the url you're at.
i gave up in the end and added the whole website to the cgi-bin directory.
