blocking sites
blocking sites
Hi guys/girls Smiley
I just started to block key words on my router to stop my teenage kids doing what teens do Smiley
I would like to use the router thats under my control just to make sure they havent found a way round the security on their computer {dam teen hackers Smiley }
I would love to find an online list of bad sites I can just copy and past in to the box for blocking bad sites.
Its just for an extra check and some more peace of mind.
It would save a lot of work :?
blocking sites
There are lists of bad sites, that can be added into your host file, but they tend to be more like anti-spyware or anti-porn.
I guess a lot depends on what you really want to block and stop.
blocking sites
You will be better off buying a package that does the blocking for you as you have no hope of blocking the number of sites out there that kids should not have access to.
Have a look at CyberSitter which has a lot of controls and is easy to setup and configure. It is also self updating with new blockings and can be enabled on certain usernames and not on others..
