aspx filetype
Fixes: 142
aspx filetype
Hi
After completing an on-line form I requested a print-out before submitting to proof-read.
On clicking the print button I was offered a save dialogue box and the resultant file had the .aspx extension.
I have no idea about his file type and a Google search left me even more bewisldered.
Has this been a result of a bug in the web site or can the garbage contained with the file actually be printable? If so, how?
Cheers
Forum Moderator and Customer
aspx filetype
It's an ASP (active Server Pages) file. i.e. a Microsoft web programming language to create dynamic web pages.
It sounds like the link you clicked on to produce your printout called a .apsx file which the web server it is running on does not recognise, so instead of 'interpreting' the asp language in the file to produce HTML, it gives the option to download because it does not know what to do with that file type.
Fixes: 142
aspx filetype
Thanks for that Peter.
I've written to the company regarding this.
Cheers
Fixes: 142
aspx filetype
Have had a reply and it seems the co. is aware of the problem.
At least I know it was't me Smiley
