adaware
tonka
adaware
hi folks,
just wondering if you could give me some information as to cookies detectors, i am currently running adaware se and was wondering if there was anything else out there i could run along side it (free if possible)i also run vnc so i dont want it picking that up as a false virus.
adaware
Spybot search and Destroy is another good one.
pcorker
adaware
spywareinfo has some good ideas. I have used their Hijack This... to spot stubborn stuff myself but it needs lots of care. I also always use the IE-spyad "blocker" they list which I find works well and very easily (it's website makes an interesting read or just scroll the page to the big download box and get the IE-spyad.exe from there.) Both are free.
EDIT: and BHODemon for a very quick spot check for an active browser hijacker perhaps before using removal software.
bobgidden
adaware
You could look at SpywareGuard and Prevx for continuous monitoring of incoming nasties.
HTH
BobG
adaware
General: Essential Security software tutorial has lots of info and worth a read.
