X-lite setup with Linksys wireless router.
Can anybody help me with the setup of my x-lite. I've followed the setup guide. I've got no firewall set on the router and there's nothing odd with the setup but I still get registration error 479 - we don't accept private ip contacts.
Anybody help?Huh
if you goto
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
choose your router and then xlite it will show you step by step instructioins on the setup.
You do need to have a fixed ip on your pc not one issued by dhcp.
I had this problem. Did you use the set up guide for X Lite on this site? If so it's wrong!
Here's an excerpt from the reply I got to my ticket.....
Apologies there is a slight error on the setup guide which is going to correct shortly.
On the topology tab of the settings please select "Discover Global Address" and then set the stun server to stun.counterpath.net
Hope this helps.
It's got rid of the 479 code, now I've got a 401 instead! :roll:
Cheers,
Gavin Smiley
