X-Lite 3 Problems - HELP!!!
Hi all,
Just started using X-Lite recently, with no probs at all. (I have a Netgear ProSafe VPN Wireless router for broadband access at home).
I though I'd be smart and upgrade to version 3 of the X-Lite software, which has only recently been released.
Installation went well - except - all I get now on the screen of the phone is
"Registration error 479: we don't accept private IP contacts".
Don't understand why the previous version was error free and this problem has only now appeared. I haven't made any changes to the router in between either!!
Any pointers would be appreciated.. (ps I've opened the 4 ports listed in the help files within the router)..
cheers
Ross :x
1 REPLY
Problem sorted
Hi All..
Just a quick update on my posted problem:
I managed to source some info on this particular problem within the X-Lite site itself. Apparently, if you're getting the 479 error - simply specify a STUN server as follows: stun.counterpath.net - and all will be well!
Hope this helps - Oh and support - if you read these posts, please make sure your setup instructions reflect the actual product which you recommend users to download etc. Its only version 3 that's now available, and your instructions are out of date & unhelpful.
regards
Ross
