Whats best router?
Whats best router?
What would be the best router for me to get?
I need a 4 port one because i have four computers here, and i would need it to be really good for gaming and able to turn nat off.
Blackthornehous
Whats best router?
I guess you'll get as many replies as there are routers! However, I've always had the Netgear DG834G which, so far, has been trouble free. Firmware updates are easily installed. Coupled with this, I run a Buffalo Linkstation NAS device attached to the router. Hope this helps.
orrery
Whats best router?
I have a Linksys WAG54G-SX2 which appears very good.
I threw out a Netgear due to overheating and poor firmware, but it appears that they have resolved these issues. Lynksys have been unreliable in that 2 out of 4 boxes I have bought have failed.
Netgear are better to set up.
If you are buying a WiFi device, the MIMO devices give significantly better range and are well worth the extra cost - again the Netgear appear excellent.
regards, Ian
Whats best router?
Thanks so far.
What one of these three products is the best, i know how to setup the d-link one as i had to set one up for my friend.
http://www.ebuyer.com/UK/product/62676
http://www.ebuyer.com/UK/product/110271
http://www.ebuyer.com/UK/product/52754
Whats best router?
I use the speedtouch 716v5 wl its comes with a set of plugs on the back to connect 2 normal phones so you can make up to 240 min of calls a month with your F9 allowance free. Nobody can tell the differance in call quality and no stupid headsets. Why waste the free allownce
Michael
