What hardware do I need?
I want to try this VoIP on the cheap :-)
I already have a ADSL Wireless Firewall Router and a normal BT phone. I want to be able to connect my phone to some piece of hardware and then connection this to my router. I need some advice on what I need to get me going.
I would rather not use the software phone option because I would like to demo it to the wife via our current phone (Or an alternative phone).
Regards
Billy
Sorry forgot to say that I want to try the SIP route rather than the Skype route.
powernumpty
You could use something like a Sipura 3000 or another "ATA"
It allows you to use standard phones as IP phones.
I'm sure there were other posts on this, search the forum and google
(http://www.voxilla.com has quite a few details)
What is ATA? is it a Phone Adapter? If it is do i just need this to get up and running because they are a lot cheaper than a VoIP router. Could I just get a Phone Adpater and plus my phone into one end and my normal router into the other end then I can access the SIP config on the Phone adapter and I'm up and running?
glloyd
What ever you do don't buy the ZYXEL 2002L on sale from PlusNet it's full off bugs and ZYXEL support is next to useless. There is a firmware update due, or so they say, but don't seem in any hurry to release it. 70 quids worth of junk in my opinion.
Point noted ...
I have found out on another forum that 'yes' the phone adapter plugs into a normal router and the normal bt phone plugs into the phone adapter. You access the web interface of the phone adapter to configure your SIP info.
Another question :-) if I get an IP phone will this perform the same function. Can I just plug my IP phone into my normal router (or do I need a special VoIP router now) and then I access the web interface of the IP phone to configure my SIP info?
glloyd
Yes you can get a VOIP SIP phone to plug directly into your router, there are several available.
Cool, so I just connect the IP phone to my router and then access the Phone's web interface and setup the SIP config?
How does a company that has hundreds of IP Phones do this then, surely they don't access them one at a time, do they? Is that maybe where the VoIP router comes into effect?
LiamM
Personally I prefer the ATA - Analog Phone option. Found them to be more reliable than VOIP IP phones in the past for some reason.
You can pickup an ATA on ebay for £35 these days.
What about sound quality?
A normal phone will have to have it signal converted to a digital but I presume an IP Phone is already digital, maybe?
LiamM
Notice nothing wrong with sound quality at all. SIP - SIP calls are better than PSTN but thats due to the telephone line at the other end.
