Webspace error
Webspace error
I uploaded 7MB worth of files to my 25MB space
but the webspace in the web settings menu still says i'm using 3MB
and the files i uploaded arnt loading onto the program i am using
whats happening?
i know the files are there coz i used cuteftp to upload them
i've connected it again to check whether the file is still there
Webspace error
THat information only updates every 24 hours IIRC.
Webspace error
ok....does plus.net support php?
Webspace error
some1 told me that my server doesnt support php
and becoz of that i cant run a radio blog from www.radioblogclub.com
but i see a forum section dedicated to php/cgi/mysql
do i need to upgrade to get php support?
csogilvie
Webspace error
PHP is supported on the CGI server - more information on activating the CGI is available in the Tutorials and FAQs forum.
Webspace error
# Neither PHP nor Perl cgi will work at all on PlusNet if you have not activated CGI using the PlusNet Portal. For many PHP and Perl applications, you probably also need to activate MySQL.
# Currently, you can activate both these special PlusNet website services from the Portal's Website settings facility.
i dont see an option to turn these on...only thing i see is "my webspace"
To activate your CGI space simply go to 'My Website' within 'My Control Panel' on the portal and click on 'Configure CGI'.
Evil where issit?
csogilvie
Webspace error
You on HomeSurf or BizSurf - if so you don't get CGI access.
Webspace error
aiight..thanks..
Webspace error
hey, now i'm using tripod to host my readio.blog (www.radioblogclub.com)
but i need some testers to see what happens to when u go to my site
www.tamil.plus.com
i need to know what happens in IE since IE is the popular browser
whats funny is that i can get php support from tripod a free service and i dont get php from plus.net when i pay for it...[ :lol: :lol: :lol:
[Moderator note (by acarr) : Removed excessive smillies]
Webspace error
The product specification is clearly available before you signup for the accounts.
