Websites
Websites
I am looking to update my website, from it's current format to a portal site, I have looked at the following
http://www.metadot.com/
http://phpwebsite.appstate.edu/index.php?&MMN_position=1:1
Has any one used these open source software to build a website and can they be uses on PlusNet web space.
Alteratitivly can anyone recommend an alternative
Many Thanks
Cheers
David
Websites
Just noted if you try your website http://www.wma05.plus.com/ you get a dir listing did you know?
Your better putting an index.htm file there and giving a list of the other sites
Websites
mwright,
Thanks for the tip I will do this.
The individual websites are accesd by their own URL's i.e. www.stonehavenlions.org.uk, rather than via the plusnet web address, I never noticed the problem.
Cheers
David
Websites
Woah small world!
My g/f is from Stonehaven. She says she always looked forward to the Lions Club santa passing her door every year.
Websites
Have you looked at Mambo?
http://www.mamboserver.com
See my posting at the end of this thread for installation instructions.
http://portal.plus.net/central/forums/viewtopic.php?t=13178
Chilly
