Website uploading error
Hi there.
Wondering if someone can help .... I have designed a site in frontpage and have tried to publish it from there. It comes back saying everything is fine and it has been u[ploaded to http://fp.stuartc.plus.com/ - however when I got to my domain the site is not there neither is it under www.stuartc.plus.com.
I then downloaded CuteFTP to try that way and I got an error saying I do not have permission to upload ?!?!?!
Any ides Huh
Frontpage sites are hosted on a different system to the normal webserver, and as such, you can't see them via the normal http://www.stuartc.plus.com/ address.
Point your browser at http://fp.stuartc.plus.com/
I can see a framed page titled "Stuart & Michelle's Window on the Web !
Thanks for that - you got the right site ... how do I direct my domain to this page ??
SC
Unfortunatley, you can't point domains to the fp webspace in the same way you can for the cgi or main webspace. There's only really one way around this. Point your domain to the regular webspace, and then use a framset to include the fp page.
Further details on doing this are available here.
Thanks for your help - got the necessary files and amended the index.htm file, however whenever I tried to upload this using Cute I get an error saying I don't have permission ? Any idea's ?
Cheers.
SC
csogilvie
Make sure you've changed into the htdocs folder and not to the folder you get when you login (with htdocs and logs)`
Thanks Alot .... that seems to have sorted out the problem ...
Rgds.
SC
