Website building
Website building
Hi Folks
Has any one any idears on what books or software to use to build and upload a site. As I think I would like to try and not rely on the PlusNet Website builder.
and go it alone just using the ISP to upload same.
Obliged Job
Website building
Dreamweaver MX to build the site. WS_FTP Pro to upload etc. There's quite a few books available from such as PC world i.e. "Create a website in no time", "Website design in easy steps" etc
Ken
Website building
Dreamweaver has a built in ftp so you can upload pages from within the programe. You probaly need a simpler prog if you have MS Office you may have front page built in or at a push word will do webpage.
You can search the net for Free webpage building software or editors, there a lot of good ones free.
I always go to the libary as a first port of call as they have loads of books on web building and again its free.
vic_newey
Website building
I used Sierra web artist for my website, it cost £17 & it has everything you could want , you just drag & drop backgrounds, pictures banners ,special effects, links etc.
when you have finished you just click a button & it converts everything into HTML & then you click to upload & it does just that.
take a look at my website, www.miniatures.kirion.net & see how I did, I also loaded the website on to plusnet but not worked on it yet to change some of the links. My kirion website is linked all over the world & it will be a long time before I can change it all to plusnet.
