WebMail
WebMail
If I want to use webmail to collect mail from an external POP3 account, is there anyway of automatically deleting them from the external mail server once I have them in webmail ?
lowry
WebMail
If you do this, when you download the mail using webmail it will just be working like a software mail client on your pc would and so it downloads the messages from the external mail server to the PlusNet webmail server, from which you can then delete/move the mail.
I think that, like Outlook Express (unless you have "leave mail on incoming mail server" ticked in the tools>options menu), the mail will be removed from the server once downloaded in to webmail.
I hope that helps,
matt Wink
WebMail
Thanks for your reply, but that's the problem, I can't find the option 'leave mail on incoming mail server' on webmail, so I can't untick it.
