Web Space As A File Transfer
Hoe do I upload a file to my web space so that when someone goes to my page they can click on a link and the file will be saved to their pc.
Thanks in advance.
Moderators note by John (johnessex) Topic moved to a more appropriate part of the forums
yazak
you simple upload as any other file and place a link to it
If it is a exe the computer will ask if they want to download it
:shock:
Thank you for that...
Links for file downloads.
Just a quick tip! make sure that the path you write in for the link is absolutely correct otherwise it probably wont work
For Example: Path would be http://www.domainname.co.uk/htdocs/myfiles/filename.exe (or whatever the file extension is).
**Also if you've done the above correctly you should be able to test that it actually works yourself bye clicking on the link you created and by seing if you yourself can now download the file/s. If it fails then go back and check your syntax for the path or link.
**Should work fine if the path statement is correct though.
Regards Ivan Cool
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Ivan - thank you for your help and advice, much appreciated.
