Web Address Issue
Web Address Issue
Can anyone using PlusNet Broadband get the web address below to display on thier screen:
www.middlesexccc.com
I cannot on either of my two PCs using my Plusnet connect.
I have tried disabling all my security software and now difference.
Fixes: 5
Web Address Issue
Fine for me on 2 different PlusNet connections and a non PlusNet connection. What DNS servers are you using?
Phil
Web Address Issue
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
Optional tertiary DNS server 212.159.6.9
I assume these are what you mean - I got them rom my connection settings.
When I disconnected my Broadband connection and accessed the internet using Plusnet's dial-up connection, I manage to get onto the web site.
Any ideas?
Web Address Issue
It could be the DNS Cache on your machine.
Try flushing it, using IPCONFIG /FLUSHDNS
Web Address Issue
Sorry but....
Try using IPCONFIG /FLUSHDNS means nothing to me. Can you provide or point me to some instructions.
Web Address Issue
Sorry,
It's run from a command prompt in windows, it's a DOS based command.
Press Start, Select Run
In the Box that opens type "CMD" and click OK
A small DOS window should appear.
Within that type "IPCONFIG /FLUSHDNS" (Doesn't need to be in caps)
Web Address Issue
I successfully flushed the DNS Resolver Cache but it did not make any difference.
Is it relevant that I can access the site with a dial-up connecton but not with my Broad band connection?
Web Address Issue
It just means your probably hitting different DNS servers to get the IP address of the site.
Try, going into dial-up, opening a DOS command prompt (as previously described), type in Ping www.<the web address>
It should give you an IP address in brackets around the WWW address.
Go into broadband, in a browser, type "http://<ip address>
and see what happens, you may need to add a slash at the end.
Web Address Issue
On dial-up:
Ping www.middlesexccc.com - successfully connected 217.158.60.130
Ping 217.158.60.130 - successfully connected 217.158.60.130
On Broadband:
Using Internet Explorer:
www.middlesexccc.com - nothing
217.158.60.130 - nothing
Web Address Issue
hmmm, try downloading a different browser. Are you using any proxy server settings within internet explorer?
Web Address Issue
Now you are asking me to do something I am not happy doing...why wuld i want to download a different browser, I am happy with IE.
It works for all my freinds, so why does it not work for me?
Can you call me on
Web Address Issue
Doublesix,
Gadgetboy has a good and valid point. In my eyes IE isnt worth spitting on and therefore use a browser called firefox.
My second point would be to edit your post and take your mobile number out and send it to gadgetboy via PM so that you dont have any tom d1ck or harry phone you up at any god given hours of the day.
Regards,
Web Address Issue
Hi if your happy with IE stick to IE, but I wanted to try the other browser, to identify whether it was something within the settings of IE. I'm not asking you to switch for good.
Scrub your number as well, msn me is better, you can get to my msn / e-mail addy from the sig.
