Wanting to use a handset rather than a soft phone
Hi Just getting into this Broadband phone stuff. However I would prefer NOT to use the software downloadable 'phone' and instead use a handset.
Ideally I would like to have a single handset which I can use to make AND receive Broadband phone calls as well as usual land line ones.
Anybody have any experience of doing this? Also what equipment and where to get it from would be VERY WELCOME.
I did some research and found a 'Dual Phone 3088' on DABS which seemed to handle VOIP and normal land lines so I ordered it, but it only seems to work with Skype. Does anybody know if I could change the setting and use it with Plustalk?
All help gratefully received.
Thanks in advance.
Purvez
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 159
I'm not sure about the phone you have referenced, however if you look at the bottom of this page there are some items of hardware we do support.
 Chris Parr
 Plusnet Staff
