Waitec E-ZI Phone
Waitec E-ZI Phone
My supplier assures me that the 'Waitec' will work on my Plus Talk connection. My guess is that in the 'System settings' of the X-lite software 'Speaker audio device' & the 'Microphone audio device' settings will need to be changed to the Waitec ?
Any comments will appreciated.
Waitec E-ZI Phone
I have a Waitec E-ZI phone. You will need to change your settings as you suggest. You will want to leave the "Ring Audio Device" as your sound card. When you first install your usb phone it will become the default sound device for windows - you will need to reset this in Control Panel. To allow your usb phone keypad to work you will need to download and install X-LiteMate from the Waitec site.
Waitec E-ZI Phone
I downloaded the file thanks. While i was on the site i found 'SJPhoneMate.zip' so i had a brainwave. Went to the SJ site and downloaded thir voip software, tried it out. With the set up i have at the minute (microphone and headphones) better quality.
:idea:
