WMF exploit - I have just fallen for it!
I have started the new year thinking that I was fairly PC savvy only to open an e-mail from a
David Taylor @ Tradersworld.com
(DONT go there!)
The content of the e-mail
Hello,
John asked me to send out the new website template, I have uploaded the initial design here
and there is a website link, obviously I shall not post it and yes I went there Shockedops:
This can exploit because of a windows error in the display module for WMF images and embedded harmful code can be executed. Even viewing the preview of a WMF camouflaged as a JPG image can install a backdoor on your PC.
Microsoft hasn't provided an official patch so far to close this flaw, and all Windows versions are affected by this problem! WMF exploits also work with limited rights user accounts.
However Castlecops and sunbelt are hosting a temporary fix. http://castlecops.com/a6436-Newest_WMF_Exploit_Patch_Saves_the_Day.html
Hope you aren't as stupid as me!
there are three ways to protect against this:
1) unload the dlls
2) use the regpatch
3) download the hotfix from hexblog
if you do all three then reboot you will be safe (or just (3)) so yea, have fun Smiley
Re: WMF exploit - I have just fallen for it!
Don't feel to beat up about it, everyone gets caught out from time to time.
Sorry to hear you got a nasty. Sad
Could you tell me please, when you say "camouflaged as a JPG image", do you mean the extension ".jpg" is visable in the link, but the true extension is hidden?
What I mean is, one of the first things I do in a list of "hardening" after an install of windows, is to go to "folder options" and un-check "Hide extensions for known file types". What I am asking is were you caught out because you clicked on something that appeared like this:-
But was really this:-
    nasty.jpg.exe
Or is it a case that you just need to have viewed an infected jpg from a web site? :?
**EDIT**
Hmm never mind, I am looking at some security sites about it, which indicate it is rather more than I was thinking. Shockedops:
it doesnt need any ending at all, for instance any line at all can give it to you.
I have been using the tempory fix against these "wmf" exploits for the past few days, but an official fix came via microsoft yesterday. (friday).
Just thought I would let bluebellhouse and any other interested peeps know. (Particularly peeps who don't have windows updates set to auto) Smiley
If you use Windows regardless of what Internet browser you are using - then your computer is very vunerable - if your browser can display pictures - as bluebellhouse has found out.
This exploit takes advantage of the Windows Media Format (WMF). It's not limited to WMF files, e.g., it can occur under any graphical extension (jpg, gif, etc.). You only have to visit a rouge web-site and your computer will be infected - without clicking any links! This also applies to "pictures" embedded within or attached to emails and presumably the same applies to newsgroups.
I understand the exploit uses a Windows feature that has always existed which allows executable code to be contained within .wmf files. However the way this has been implemented - code within any media file is executed. Therefore files with .gif .jpg .png etc... extensions can carry a malicious payload. The worrying thing is how long this has been exploited - as I heard something about infection via jpg file a year or so ago - and rubbished it! However since the publication of this exploit over the Christmas period - use of this exploit has snowballed.
This exploit is currently billed as the worst security hole in Windows history - affecting ALL versions of Windows past and present. More reading and a WMF Vulnerability Checker can be found at - http://www.hexblog.com/2006/01/wmf_vulnerability_checker.html#more .
At the time of this posting Microsoft does not appear to be releasing a fix for Windows98 (earlier versions though probably affected - are no longer supported in any case). For more details and patches for later Windows versions see - Microsoft Security Bulletin MS06-001 at - http://www.microsoft.com/technet/security/Bulletin/MS06-001.mspx
