Voice over IP
Voice over IP
I have heard that you can make telephone calls over the internet, and even do video conferencing.
How does one go about doing that then?
Voice over IP
On a cheap note .... what about using MSN .... video conferencing, voice, drawing etc.
Otherwise purchase some heafty equipment from Cisco .... that'll give you all you need too.
Spark88
shellsong
Voice over IP
Skype is becoming a pretty popular VoIP solution, it provides high quality sound, 256bit encryption and works through NATs, routers and firewalls without any need to change configurations. (And it's free)
