VOIP problems at peak times ???
davebrown
I posted this in the Community Support forum and got no reply...
Just wondering if anyone has noticed poor quality VOIP at peak times.
I don’t use PlusTalk as I found it very unreliable, I changed to another VOIP provider last year and have had superb audio quality
Over the last 3 or 4 week I have noticed during peak times, poor quality audio and the odd dropout
Speed tests / downloads & browsing are fine
One reason I stayed with PlusNet was the knowledge that the system IS managed and VOIP packets get a very high priority on the network.
Dave
glloyd
The quality has dropped at all times. It used to be as good as normal L/Line but recently you get drop outs and poor audio quality.
davebrown
Thanks for the reply George,
I started a thread on this in Community Support
http://portal.plus.net/central/forums/viewtopic.php?t=56614
I have also opened a ticket, no reply as yet.
Regards,
Dave
