VNC on plus net
Fixes: 5
VNC on plus net
Hi
Can anybody help me. I used to use VNC to access my work computer from home over my Plus Net ADSL connection, which I can no longer do. I can connect from other computers at work, and outside of work. My set up uses a Nokia IP55 router, and I have 3 computers connected to it. I can connect when I use the backup modem on the router, although that is extremely slow.
Can any suggest anything?
Phil
1 REPLY
VNC on plus net
You probally need to forward some ports, I use VNC without having to for my server, but guess your router has a active firewall so probably have to, so best to read through this faq depending if using VPN or not
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
