Using your ps2 online
richard-
Hi I was wondering how I use my ps2 online, Im going to get one of the new
slimline ones because my other one has broken, I read it has an in built
ethernet, I have a 4 port router and plusnets premier 512k ...
What else do I need
Yep, the new one has an integrated ethernet port. All you'll need is a straight cat5 cable to connect the PS2 to the router (exactly the same one you would use to connect your PC).
You will also need to add a couple of rules to your router's firewall in order for Central Station t work.
If you need any help, post back, and I can give you the port numbers.
You'll also need to do the same for most PS2 On-Line games.
Aaron
richard-
Yeah the ports rules would be excellent I have a netgear DG834G wireless
Thanks Smiley
