Using front page to upload my website to plus net webspace.
i loaded a website i have created in frontpage 2003 onto my webspace using ftp last xmas everything worked fine. sundenly it stopped working i had not amended it or touched it in any way.
now no matter how many times i load it it still does not work....... very fustrating.
can anyone advise how to rectify this problem..... please
Also 2nd question i have activated my webspace on plusnet's Frontpage services
can i just load my website up here and should it then work?
is using Frontpage services better then FT?
site is at www.viatopia.plus.com
many thanks.
All help gratefully recieved.
Frompage extentions can be a pain to manage. You are also required to use a different server for your website.
Unless you need Frontpage specific extentions, the your best staying with FTP.
http://www.viatopia.plus.com/
When a user visits your website, it either supplies the specific file they request, or if not specific request is made, a default file is served.
This is known as a index file, and normaly named index.html
This file is currently missing from your webspace. Have you deleted this? Is it available to re-upload?
thanks for your message
yes i had deleted all the files becuase of the problem i detailed above. but even when i put them back some how it is not updating my hyper links from the path in my computrer to the path within the webspace.
can you help?
What does Frontpage have your Default/Home page listed as?
index.htm i am just uploading the site using ftp
hi
does anyone know why when i upload files it does not update my hyper links from the path in my computrer to the path within the webspace?
:twisted:
You need to ensure that the hyperlinks to other pages within your site are `relative` i.e.
 ./page.html
And not the full path on your computer.
Chilly
sorry i am not following you i have basic knowledge here
please bear with me....
OK, I have moved to my machine with FrontPage on it.
Right Click on a hyperlink (in FrontPage) and choose `Hyperlink properties`
Look in the address link near the bottom of the dialog box.
If this gives a full path like
D:\My Documents\My Webs\myweb5\intro.htm
This will not work on your web site it should be changed to;
 intro.htm
or
 ../intro.htm
or
 ../folder/intro.htm
Depending on the relative position of the file that you are linking to.
Hyperlinks to external site should look like;
 http://www.techcomedy.com/
Chilly
i have tried the code
../folder/intro.htm
but still it does not work
my website is www.viatopia.plus.com
mossgrove
Looking at the source of your site, all your images point to a directory on the PC - "file:\\\ etc." you need to delete everything in the fie address upto but no including " \images" The reference will then point to your webspace - this is called relative addressing. You should be able to select an option "use relative addressing" when you insert the image in FrontPage.
Check your e-mail. I have sent you a version of your site that "should" have the correct referances.
Chilly
