Using a cheap USB handset
Dizzley
Ages ago, I got a cheap USB handset that came with Skypemate. How do I get this to work with X-Lite or equivalent? There doesn't appear to be a driver with the phone.
Pete
Cheap USB handset
I have a cheap handset bought for use with Skype.
I appears to pick up OK with xLite, there is possibly a problem in it changing the sound settings to putting everything out through the handset rather than speakers.
Once my 240 inclusive minutes appear I may have a better idea re this
pint
If your after a USB phone to use with Xlite, then either the Cyberphone K or cyberphone W will work, with the number keys working as well.
if you go onto the X-lite suport site/forums by clicking on the question mark on the Xlite phone you should be able to get more information.
I have set the USB settings in System Settings as
Preferred USB phone (default)
Speaker Audio device: Generic USB Audio Device
Microphone Audio device: Generic USB Audio Device
Ring Audio device: Sound card
and it all seems to behave. Certainly it quite happily made a call when I got home this evening, the inclusive minutes having come online.
I am running XP SP2 on a new machine since I got the USB phone and it just found the device.
Perhaps I was just lucky, but the phone is a no name cheapy from Ebay via Hong Kong if I remember rightly.
Dizzley
Thanks for all that. The phone mic and speaker now work fine with X-Lite but the keypad isn't supported and never will be.
Pete
Dizzley
Woohoo! Cheesy
I found a driver for my typical cheap handset here: http://www.echostore.com/skype-phone-mobile.html.
They have a X-Lite driver/companion program here:
http://help.echostore.com/Skypephones/X-TenMate.zip
It works just like the SkypeMate program which came with the phone.
Now the keypad works fine.
Interesting site too.
Yours happily,
Pete
Dizzley
If anyone's interested: these handsets appear to be the same ones available from Tesco for their VOIP product and at £30 a pair (£20 for one) they look like a bargain if you want to get using PlusTalk quickly.
Pete
