Using IP address
glloyd
Using IP address
Just a thought, not tried it but can you call someone on VOIP using their IP address if they are not on a service peered with PlusNet? I know it works with other PlusTalk users.
MrToast
Using IP address
IP Telephony is Peer to Peer.
If you have some other method of discovering the destination IP address then you could set up a call.
Using IP address
VOIP isnt a plus.net thing
Its an internet thing. if your friends connected then you can setup VOIP between the two of you
