UserAccount
UserAccount
I've just set up PlusTalk on my home PC and Laptop. How can I use the Laptop to call home when I'm away, as they both have the same account details?
1 REPLY
UserAccount
You cannot use plustalk on a connection that does not belong to plusnet.
In short if your on business and start using a line and connection supplied by NTL then you cannot use this. ( Unless someones changed the rulebook on me ).
To do this I would use THIS VoIP Provider to achieve the desired effect. £5.90 gets you 1000 minutes to any landline inside of the uk Wink
Regards,
