Uploading
Uploading
I am new to this and I cannot access ftp.plus net. I get a message this page cannot be found. Would be grateful for any help.
Kevin
Barnstaple
:lol:
Uploading
Was it a typo that you left out a dot in the above? As it should be ftp.plus.net. Smiley
Thomas
Uploading
Yes you are right, it was a typo, but I did not mis-type it into the address bar. I can't understand, I just keep being told that this page cannt be found
K
Uploading
Well, which browser are you using? Not all browsers support FTP, in which case, you'd need an FTP client.
Thomas
Uploading
An FTP connection is not the same as viewing a page in your browser. It is a method for transfering files to from a remote server or system - which I assume is what you are trying to do. While some browsers will allow you to do some FTP transfers (Internet Explorer is one), others don't and you will need a stand alone FTP program or 'client' as it is often refered to, to do any file transfers. There are many free versions around, just do a search on google for 'free FTP program'.
Uploading
Uploading
Hi Kevin
You should enter the URL prefixed with ftp://,
ftp://ftp.plus.net/
Using the "http://" prefix, you will get "Page can not be found", as the browser is looking for a web page.
If you are looking for a graphical ftp program, I recommend FileZilla, its free and open source.
http://filezilla.sourceforge.net/
Chilly
