Uploading to my website
Cry can anyone help i am trying to upload files to my website via a programe called WEATHER-DISPLAY soft ware .i can clearly see my files uploading but they are not showing on my site
http://www.weather-display.com/
Can you post a link to the said software.
The only one I can find is unrelated to uploading websites.
acarr:
The software is the front end to a home weather station. If you have the relative sensors, the local weather conditions are displayed by the software. The software has the capabilities to upload the data via FTP to a website.
capnerr:
I can only assume that the FTP details for the webpage that have been input into the software are incorrect. The FTP client within the software may not be sophisticated enough to generate error messages.
Use another FTP client to check if the files are present on the webspace rather than Internet Explorer or any Webpages you may have generated.
