UTStarcom F1000 WiFi VoIP Handset
Anyone using this handset with PlusTalk?
no, but currently use with sipgate.
pretty good all in all.
Its a SIP phone so no reason why it wouldn't work
Re: UTStarcom F1000 WiFi VoIP Handset
I'm using an F1000G but not directly with PlusTalk - mine's connecting to my Asterisk server. It's a good phone, although has a couple of bugs that may or may not affect you:
1. If you have STUN turned on but you're *not* going through a NAT it sends broken SIP packets. This just means you have to have STUN turned off when you're not behind a NAT (slightly annoying to have to go toggle it when I change networks)
2. It seems that sometimes the phone stops registering during a call (but not always).
Other than those minor problems, it seems like a good phone, and having just looked at the SipGate website it looks like the price has come down since I got mine a couple of months back.
