USB cordless telephone
zipadeedoodaa
I have a USB telephone with Phoneconnector, the phone is cordless.
Is it possible to use this instead of the software made available by Plusnet.
Thanks for any help provided.
Neville
1 REPLY
You need to use a client with it (there is a list of the other software you can use it with on their home page):
http://www.phoneconnector.com/
You can use it with the software Plusnet are suggesting:
http://www.phoneconnector.com/Xten.aspx
http://www.phoneconnector.com/support/Install.aspx
