Trying to upload my website but .........
Ok, here we go .........
After a major PC crash, I've been trying to re-upload my website but am coming across the message "There are too many such files to report(over 1000) and it is likely that you have built your website in a public folder.
It's probably something quite obvious - but not too me (at the moment anyway).
I'm using Terrapin FTP and haven't any similar problems before.
A bit of advice is sorely needed - so HELP!! :?
1 REPLY
Looks like terapin FTP cannot handle more than 1000 files in a folder either on your hard disk or in your webspace.
Is this true, you are uploading all your files into a single folder on your webspace? if so I suggest you try and splui them into separate folders.
Perhaps you have a lot of crap left over and you need to delete some files in the folder you are uploading to.
