Transferring domain from 123reg to plusnet.
Right i`ve done a search but cant find any posts on this.
I have registered a .com domain on 123reg and want to transfer it accross to plus net.
On plus net it says to change the dns entries on the host over to the plus net ones but when i try and change it on 123 there doesnt seem to be a dns entry.
is it the A I have to change or the CName.
Thanks for help peeps
You are choosing thr wrong item in the 123Reg control panel.
Choose the "Changes nameservers" item, just under the "Manage DNS" item.
From here, you can enter ns1.force9.net and ns2.force9.net
are these still the same... Huh many thanks..
The same as what?
If you mean are those the nameservers to use so PlusNet hosts the domain then yes.
Once you have updated 123reg you need to raise a contact us and tell PlusNet yu want your domain hosted on PlusNet.
As noted, yes.
I doubt they will change for a long time. To change these would be a administerial nightmare.
many thanks to you both for your help...
