Thunderbird to Outlook
Is thier any tools to export all my mails, my contacts from thunderbird to outlook.
I like thunderbird but i wish to use the calendar facility in outlook which at present is not in outlook.
I believe that you can get an extension for thunderbird that is a calendar.
There is help on the mozilla site for "exporting" thunderbird address book etc. I saw it yesterday - if I can refind it I will post.
Gosh it is simple, you are going to kick yourself: Wink
* Select Window | Address Book from the menu.
* Highlight the desired address book in the Address Books list.
If you are not sure which to select, choose Personal Address Book.
* Select Tools | Export... from the menu.
* Make sure Comma Separated (*.csv) is set under Format:.
* Choose a location (your Desktop, for example) and file name.
* Click Save.
The mails if you go into C:\Documents and Settings\YOURNAME\Application Data\Thunderbird\Profiles, you will find them there.
Help found here: http://kb.mozillazine.org/Export_mail_into_Outlook_(Express)_or_Apple_Mail
dude, get the calender plugin for thunderbird jebus, dont go back a step now that you have gone forward one!
whats jebus
can i have a link please Smiley
And thanks everyone above for the feedback...
holdtight
Most of the calender extensions are at mozilla.org the main site for firefox and thunderbird
