Suspected Virus/spyware Need help please
Hey all, A few days ago I started to notice a lot of packets trying to be sent on port 137 and port 520. I use protowall to block undesirable scans and have noticed this:
Packet to "IANA - Multicast, Kuang2thevirus, IANA Reserved" (255.255.255.255) [protocol: UDP / destport: 137]
and packet to "IANA - Multicast, Kuang2TheVirus, IANA Reserved (224.0.0.9) [protocol: UDP / destport: 520]
I keep having these scans/packets sent every few minutes and especially when I first connect to the internet. It does affect my speed of my computer and internet connection at times. My virus scan doesn't pick up anything (mcafee) and I have several anti spyware programs which haven't picked anything up either.
Anyone got any suggestions? I'm just about fed up enough to reformat.
Regards
Andy
Have you had a look under "msconfig" to see whats being started up when you first start the PC?
You may find something in there relating to the IANA - Multicast, Kuang2thevirus, IANA message you are seeing.
If so you should be able to stop it running.
Yes, I've tried that. All the other things that startup are ok. Nothing suspicious there.
I've also looked at process running on task manager. No joy there either.
They are as they suggest Multicast packets, which by themselves, should be perfectly harmless.
Have you tried checking the support sections for the firewall, to see if it has an issue with dealing with multi-cast traffic?
Are you using an ADSL router to connect to the internet? Do you have two or more PCs networked together?
The destport 137 is one of the ports used by NetBIOS to transmit information about computer names etc. to other PCs on a peer-to-peer network. If you or any of the PCs on your network have file sharing enabled you may well get data coming in on ports 137 and 138.
The address 224.0.0.9 is used by the Routing Information Protocol (RIP) version 2. RIP allows gateways to exchange routing information with other gateways, hence why I asked if you have an ADSL router. RIP periodically broadcasts routing information using multicast address 224.0.0.9 i.e. an IP address reserved for this very purpose. Read more about RIP 2 here if you are interested.
In both cases the most interesting piece of information you haven't given is remote IP address. With this information it's easier to determine if the incoming packets are from a local network or somewhere on the internet. If either of these incoming packets is from a local network it is likely they are harmless.
Regards,
Scott
I've had a look on Mcafee's site for multicast traffic and there's not much there. I've also done a search and it seems that people have had problems with kuang2 but on port 13700.
One other thing I forgot to mention is that my firewall keeps on popping up asking me to reconnect to the internet (Connection window)
At this time I get a lot of packets trying to be sent out.
Firstly do you have UPnP enabled on your machine? Since UPnP uses an IP mask which can cover 255.255.255.255.
I use Protowall, and blocklist manager. I got the same warnings as you did and I lost my lan connection if 255.255.255.255 was blocked. I found my PC wouldn't reconnect and would self assign a new IP address, rather than use the reserved IP address from the router, and thus I'd lose my internet connection as well.
To resolve the problem I changed it to be allowed within blocklist manager and I've had no further problems since.
It's worth also mentioning that a Plus Net address is actually within the blocklists and when running you'll find some people's avatar won't display as a result of this.
hmm interesting. I'll give that a go and let you know how I get on. Thanks for your help guys Cheesy
Works fine now. Thanks for your help guys Cheesy
Very friendly people on these forums Cheesy
